gaz
Cycle Camera TV
- South Croydon
The hi-viz that is sold as cycling products has very minimal reflective bands.
in general
I have considered this, but perhaps illumination from the back. Most of my commute is unlit country road and therefore no light shining in my eyes is an advantage. My worry is that motorists cannot see me side on, when I am on unlit roundabouts. This was confirmed by the GF the other morning.
Maybe you need a light like this...
http://s5.thisnext.c...on/CA1E615F.jpg
Does this allow me to RLJ? If so it may be worth investing in one :-)
RT, Hi Viz doesn't work at night, because fluorescent colours (typically) absorb UV present in daylight, and this light is re-emitted as visible light. At night there's very little or no UV around and the average headlight doesn't emit UV. So there's effectively no fluorescence. So Hi-Viz at night doesn't really help.
Retroreflective tape is good, especially if it's low down, where dipped headlights will illuminate it. But reflectors rely upon other vehicles using lights and not everyone does.
It's always best not to rely upon someone else doing the right thing, because sometimes they don't. So RVLR compliant bright lights and reflectors are required on the bicycle.
UV LEDs are available, so it would seem possible to self-illuminate a Hi-Viz tabard / jacket using one. Different UV LEDs vary in wavelength etc. So, some research would be needed to avoid potential eye damage and or unnecessary skin exposure.
Of course, the self-illumination lights could be run-off a dynamo. If they are supplied via a sensor controlled headlight, they could switch on automatically.
Taking it back to the idea of self-illumination, any ideas whether the visibility of fluorescent clothing would at night would be improved if the bike was fitted with some sort of UV / blacklight?UV LEDs are available, so it would seem possible to self-illuminate a Hi-Viz tabard / jacket using one. Different UV LEDs vary in wavelength etc. So, some research would be needed to avoid potential eye damage and or unnecessary skin exposure.
Indeed. One flashing, one constant at each end of your bike.
But after a good set of lights, a hi viz tabard is the single best thing you can do to make yourself more visible. And you really don't need to mess about pointing lights at it - other vehicles will do that for you.
These are very visible indeed at night, even when you're waiting at give way lines and a cyclist wearing one comes along the main road.
I read a report which whilst it did like the reflective vest - it actually thought that the reflective bit on the moving ankles and knees was actually better.
Hiviz reflectives only work when lights point from in line with your own eyes towards the cyclist, and that's rarely the case when a cyclist is going along the main road, and drivers are waiting at side roads. Other peoples' lights also do nothing to illuminate the reflectives, unless inline with your own eyes.
