Wet Or Dry, Take Your Pick.
Wet or Dry
  • Wet
    Votes: 5 62.5%
  • Dry
    Votes: 3 37.5%
  • Total voters
    8
classic33
Leg End Member
If you were counting paper/working your way through paperwork, chances are you'd wet your finger/thumb to help you gain a grip.
Gymnasts and indoor climbers use French Chalk, normally, to reduce the moisture on their hands. This to help maintain their grip.
Two seperate, but opposing methods to help improve the grip. Which do you use?
screenman
Wet as powder makes a mess.
screenman
So can water.
I find water tends to clean itself up if used in very small quantities, where as powder goes all over the place. In truth they both have their uses. Mind you I spend more time with paper work than I do climbing walls, so that may influence my choice.
