£6,000 budget, recommendations welcome
djw1
Regular
Hi,
After a 3 year absence from cycling and exercise in general, I’m in the midst of getting myself back together and back on it. Without going into the specifics, lots went ‘wrong’ in my personal life and I lost all motivation for exercise amongst other things.
As you’d expect, my weight ballooned from around 12st to 16st and my level of fitness was non-existent.
I’m now well on with getting myself stronger, fitter and lighter, with almost 2 stone lost in the last 3 months alone. To motivate myself I promised I’d buy myself a new bike once I hit a certain weight and fitness, and I’m pretty much there.
I’ve currently a 5 year old Neil Pryde Bura SL. It’s a really nice bike, light (7.5kg), Ultegra 6800 kit and Dura Ace 35 wheels. But I’m thinking of retiring it as a training/winter bike.
Things look to have moved on a lot in the few years I’ve been absent. I’ve never had/used Di2 and disc brakes but they’re looking pretty standard on high end bikes now.
I’ve a budget of up to £6,000 with maybe some stretch for the right bike and looking for some suggestions.
I’m currently training for an Ironman - I’ve completed a few in the past - next year and it’s a hilly course and I’m not interested in a dedicated TT bike. I’m starting to progress to 50+ mile rides at the weekend and aiming to get towards 100 miles, which used to be pretty standard, by year end. The road surfaces I tend to use are single track, rural and as rough and crap as anything.
I’m open to an aero bike but whatever it is, it’d ideally:
Weight 8kg or less
Decent wheelset (40mm profile or thereabouts)
Ultegra or above (not interested in SRAM)
Ideally Di2 and disc brakes
Stiff but comfortable
I don’t mind if it’s ‘last years’ model etc and I’m open to a bargain.
I’m 6ft so likely to need a 56cm frame (current bike is a 56).
I’m not sure whether it’s Covid-related and manufacturing has been impacted but it looks like it’s a struggle to get hold of anything of that size. I quite like the look of this but 56cm is sold out everywhere:
https://www.pedalon.co.uk/acatalog/scott-addict-rc-pro.html
Thanks in advance.
si_c
Wirral
What about the Trek Domane SLR7 - it's an endurance focused bike with wider tyres - the weight is about 8.5kg so slightly above your initial desire - but aero framed and disc braked bikes do tend to be slightly heavier and it's got more of an aero focus - the consensus seems to be that aero trumps weight even on hilly courses.
DCLane
Cervelo S3/S5 or Ridley Noah Fast would be my suggestions. You'd get a Specialized Tarmac or similar in that as well. Many 2020 bikes are sold out and 2021's are starting to appear.
NeilPryde's are good bikes; I've just sold my Nazare as it was a bit small for me.
djw1
Regular
Thanks for the replies everyone.
I'll never understand the inverse snobbery that's present amongst cyclists. It's OK to be critical of somebody wanting to spend a lot of money on a bike, and be negative towards them, but not OK to be critical of those who want to spend less? I wouldn't comment negatively on somebody running a cheaper bike and the reverse should apply.
I already have a bike, I'm after a second one, not a whole fleet of £2K bikes.
I'm not exactly fat - well not any more, definitely not middle-aged and with a couple of Ironmans under my belt have nothing to prove.
Sigma look to have a number of models I'd be keen to see and with suitable sizes in stock. Just a shame they're 3.5 hours drive away! But it's likely the only place I'll see them all under one roof so probably worth the trip.
I'll take a look at the suggested Ridley etc too.
The Neil Pryde is a great bike but I'd like something with Di2 and discs really.
Just ignore the green eyed monster peeking through in other posts ;)
if you’re taking a trip to Sigma, add Pearsons in Sheen too. There are other high end bike shops in SW London but those two will show you a broad range. Neither stock Giant, but there’s a Giant store close by in Twickenham
Phone shops in advance to check what they have on the shop floor (potentially not your size), and make an appointment if needed. I‘d go in the week not Saturday as the traffic around both is shocking.
Nowhere closer to you with similar ranges?
alicat
Staffs
Nothing to recommend. Since I am trying to lose weight, I'm happy with heavier/cheaper bikes that provide more resistance and so more return for the time I spend cycling.
Jimidh
Midlothian
I’ve got one of these and it’s a delight to ride.
gzoom
I think with a £6K budget you cannot really go wrong with any brand, however I have struggled to justify upgrading my 2011 Madonna with DuraAce wheels.
Di2/Disc brakes are 100% nice to have, but neither will make you any faster. Bizarrely I had no issues dropping £2k on a new commuter bike, but I've found it almost impossible to justify spending £2-4K on a new bike that weighs MORE than my current bike, and looks almost identical. For example this is a used Trek Emonda I was looking to upgrade to, versus my current bike, in the end I decided I could use the money on other things :smile:.
Having a new bike to motivate you to keep going on the bike is priceless tough.
Good luck with Ironman training, I did a normal Triathlon 7 years age and came to the conclusion only a masochistic could come up with a sport that required you to run after a bike ride.....I've never experienced so much pain/cramp in any other sports than the transition bit on a Triathlon.
