derrick
- On the edge of London
Can i use V Brakes with 105 Brake Levers, does anyone know?
Cheers Colin, that looks like the way forwardBlimey - Travel Agents are £20 each!
Yes it looks like it could be Cantis, been doing a bit of research and they are fitted to a few cross bikes, So that's the way to go.Or use mini-V brakes, which need less cable pull. Or cantis for that matter.
From looking at the photo my mind cannot conceive how these work.Blimey - Travel Agents are £20 each!
I thought it was a strange idea so I looked it up ... See this PDF file.From looking at the photo my mind cannot conceive how these work.
Cheers, i think i understand it now.I thought it was a strange idea so I looked it up ... See this PDF file.
Basically, the cable is wrapped round a small pulley, emerges from a slot in the side of it, continues round a larger outer pulley and then goes to the brake. So if the inner pulley moves by 20 degrees then the outer pulley which is attached to it must also move by 20 degrees but the cable is being pulled a greater distance because of the larger diameter of the second pulley - a clever idea!
