1992 Brompton T3 Project
Gunk
Gunk
Oxford
New old stock later levers (with cable adjustment) three speed shifter and Brompton foam grips all fitted this afternoon, a real improvement whilst keeping it looking original.
Gunk
Gunk
Oxford
Also fitted some coloured clamps from my box of bits, these are really difficult to get hold of, Brompton only made them for one year in 2015.
Gunk
Gunk
Oxford
Frame clip and new suspension block finally arrived today, it no longer folds up every time you pick it up!
Original seat clamp
Replacement clamp with frame clip
Since the photos were taken, I’ve touched in the end of the frame.
Gunk
Gunk
Oxford
Final modifications to Brompton #7163. Today I fitted some dual pivot calipers off a Mk3 which are night and day compared with the original single pivot brakes, so a very worthwhile modification. The early silver dual pivot nutted calipers are a direct swap, no mods required.
It’s now virtually finished, I fitted a complete later brand new rear triangle as the original was broken around the pivot. I’ve also fitted new mudguards, a Brooks B17, later Mk3 levers and gear shifter, later Brompton foam grips, a frame clip plus new suspension block, Marathon tyres, and now later Mk3 dual pivot Calipers. I just need to get my local dealer to replace the seat insert, as although it works it’s definitely at the end of its life.
I’m really pleased with it, It’s been a big (expensive) project but an enjoyable process, I have tried to keep it looking “factory” hopefully it retains the essence of a Mk2 and still looks original, but rides like a much newer bike. This one I’m definitely keeping. perfect companion for my 2021 S6L!
Gunk
Gunk
Oxford
A few more jobs completed, I’ve just replaced the worn out chain tensioner with a brand new item, this makes a huge difference to the smoothness of the drivetrain and was not that expensive, about £20. Ì‘ve also replaced the dodgy Chinese luggage block with a genuine item and fitted a pump to the rear triangle.
Next job is to replace the plastic seat post insert which is at the end of its life, our local Brompton dealer will be doing that, as I’ve not got the reaming tool.
However Ì have now done quite a few shake down miles on it, and it rides beautifully, no creaks or rattles.
Gunk
Gunk
Oxford
I had the seat post sleeve replaced yesterday. Our local dealer Warlands did it for a reasonable £47 all in. The old one had a chunk missing out of it and the clamp had to be really tight to stop the post slipping whilst riding.
The difference is night and day, the post now glides up and down smoothly and the clamp requires hardly any tension, so well worth doing.
Gunk
Gunk
Oxford
A few photos Ì took this afternoon after a very pleasant ride in to Oxford for a coffee.
Really pleased with this one, Ì like the fact that although it has been upgraded it doesn’t look modified.
Just need to find a replacement later LHS side crank arm with the tab to stop the folding pedal hitting the frame, and an older style Brompton battery rear light, but really it’s all finished.
Gunk
Gunk
Oxford
Final job this afternoon, the replacement crank arm arrived, this is the slightly later version which has a small tab in the inside face to stop the folding pedal damaging the frame, they are very difficult to source as they only made them for a couple of years before Brompton swapped over to a spider crankset. I fitted one to my orange Brompton project and IMO it’s an essential mod. This one cost me the princely sum of £6.00 complete with a 54T chain wheel and chain guard which I’ll sell (now FS in the classifieds), so an excellent result!
The new one is on the right.
Gunk
Gunk
Oxford
Small update, fitted the seat insert so the seat post stops exactly where you want it each time the bike is unfolded.
The rear tyre wasn’t seated properly, some strong washing up liquid and water solution plus 100psi has sorted that out. I’ve now also fitted front and rear genuine Brompton lights so it’s ready for the darker nights.
Mainly I’ve just been using it, rides completely differently to my 2021 S6L but perfect for short trips in to town. This one has probably been the most rewarding build yet, it’s just ended up as such a nice well sorted bike, it’s also been useful having two Bromptons, visitors have borrowed them, mainly to cycle to the pub!
rogerzilla
I have the seat bush reamer and several lifetimes' supply* of bushes, bought through a side channel at a time when Brompton refused to sell tools to end users. Also have the Brommieplus rear hinge reamer, which is better than the Brompton one.
*When mine was resprayed (crap factory paint fell off after 18 months), I glued in one of the pre-reamed seat bushes and it works perfectly, so I've never actually had to use the seat reamer!
