biggs682
Touch it up and ride it
- Northamptonshire
Ah okMines an older Dolomite with rim brakes, but SKS guards fit it most pleasantly and 28C tyres just fit underneath.
I can see those workingI've got some Bontrager guards on mine. Something like this. Mine's either a 2016 or 2015 (can't remember which) but it does have discs. The brackets on the guards do rattle quite a bit though...
They really are very good, extremely easy to fit.I can see those working
The rear is on just the one's I had already the stays won't adjust to the fork mount but I have a plan that I will try at the weekend.They really are very good, extremely easy to fit.
As noted above the plastic rear stay bracket does rattle a bit on my Domane, fixed this by replacing with an aluminium bracket I could shape to fit.
It's not a bad rattle but any noise annoys me.
They won't set your pants ablaze with excitement, but on a rainy commute home in a crosswind there are much worse bikes to be on.
Being picky the brakes are not the best but that could be down to the pads as I don't know what history they have .
From the picture you've posted above seems they are TRP Spyres which I find to be excellent brakes. I'd suggest giving the rotors a good clean and swapping the pads for some new ones will sort it out - first though make sure the brakes are adjusted properly, there is quite a lot of performance lost if the pads are not adjusted so they rest ~1mm or less from the rotor.
Yes they are and i have just been looking at pads , trying to decide which ones to go for
