Just use the same shorts on the return-will be fine.
Out of interest, where to/from on the TPT?
14 - 18 degrees and you are wearing a long sleeved base layer :Owell, I broadly have 4 outfits for commuting dependant upon feels like temperature:
1. 18 deg plus:- shorts and summer top
2. 14-18 deg: shorts, summer top & base layer. If base layer doesn't have long arms then will wear arm warmers.
3. 4-14 deg: longs, shorts underneath, autumn fleeced lined top, base layer (may not bother with base layer if 12-14 deg)
4. below 4: base layer leggings, longs, shorts underneath,base layer top (2 base layers if below zero), winter soft shell jacket.
Oh, and you'll need a load of shorts too. A clean paif for each day.
OK-I know the route along the TPT all the way through Widnes and Liverpool and broadly know the turn off that takes you into Liverpool.
The bit around Speke is a bit crap and might be a bit of a bind doing it all the time (loads of glass on the underpass too). Might want to detour that bit.
I would also look at a few different route options because i) the TPT might be closed now and then, ii) makes it more interesting and iii)on road is likely to be a bit faster (in particular if your up your speed).
The main problem is crossing Speke Boulevard (which the underpass at speke goes under).
In the first instance, follow the TPT route and use the underpass. Then you know the default way.
Then, hop over to the Morrisons (about 1/4 mile west of the underpass) and go across the junction by using the road and the trafic lights. Google maps should show you although IIRC the Morrisons has been there less than a year so might not show on google maps?
I'm afraid I don't have a great solution for avoiding Speke, someone else might know a good alternative.
And I'm aware (having done it once) that the on road routes to get to widnes from east liverpool aren't spectacular, but if you leave early enough the traffic should be light enough.
Another road option might be via Hough Green and Netherley so....over the bridge, Ditton Rd, St Michael's Rd, Ditchfield Rd, Netherley Rd, Childwall Rd, Picton Rd. Childwall Valley would be a bit of an uphill drag but deffo an option.
You're right, Woolton Rd is the better option.Or even Dundalk Road/Hale Road then Liverpool Road until it becomes the Netherly Road! FWIW I commute Liverpool City Centre-Widnes via Woolton Road/Netherly Rd, I prefer that route into the city via the sports park and Lawrence Road rather than Picton and Childwall Valley. To add to the confusion you can get off the TPT pretty much on Woolton Rd at Gatacre Brow!
That's pretty much word-for-word what I was going to write! There's usually a strong wind on the prom blowing from the Irish Sea, so I'd probably head into Liverpool via the TPT and enjoy the tailwind heading home along the exposed coastThe TPT bit by the underpass in Speke is awful. You could take Ramsbrook Lane in Hale then left onto Higher Lane to Halewood where you can pick up the TPT again at Halewood Park (or alternatively come off the TPT at Pickerings Pasture in Halebank follow the road out of the car park then go straight across the lights on to Halebank Road, this will join Higher Lane EDIT: Lower Road/Church Road instead of Higher Road would be even quieter!), it will be quiet on those roads at that time and shouldn't add too much time.
Another option would be to go straight on through Speke past the airport and through the Estuary Business Park up to the retail park and brave Garston on the road until you get to Aigburth and can get on the prom.
Hope that helps!
