22 mile commute - what stuff do I need, and how should I start?
Mile195
West Kent
Looks like there's already a lot of sound advice on here, but I'll add my two cents anyway for good measure.
My commute is 20 miles each way and includes hills. Before I moved house it was 13 each way, and I was no stranger to long rides at weekends. Even so, it was hard when I started, not so much at the beginning of the week, but by thursday I really felt it - especially coming home. It's amazing how quick you adapt though. I do all 5 days most weeks now and I don't suffer unless I'm feeling ill. However you must pay attention to what you eat and drink over the day if you want the rides home to be as good as the rides in.
- DON'T drink tea and coffee ALL day. It dries you out, and makes you lethargic going home. Stop drinking coffee/tea by about 2pm, and sip water all day (I keep my bike 1l bottle on my desk and refill at least once).
- Don't skip breakfast. You'll be practically dead before you're even halfway. I eat porridge with a spoonful of jam every day (only takes 1 minute in the microwave). In the event that there's no milk in the fridge a couple of pieces of toast with jam is ok too.
- Snack at 16:00 (If you leave between 5 and 6). I usually have a sausage roll, a sandwich, some pasta etc. Just make sure it has plenty of carbs in it.
- If you hit the wall halfway home: keep a bar of chocolate or something in your bag. This doesn't happen to me often. Perhaps once or twice every 6 months, but when it does I've usually had a full-on day, or not eaten properly. A Mars bar will perk you up enough to get home. On the advice of another CC member, I often keep some fig rolls in my bag which are quite good too.
For clothing, I keep a thermometer on the outside of my kitchen window, and these are my outfits:
- Above 12C: Full summer gear (possibly with arm warmers if on the limit), no gloves
- 8-12C: Long sleeved top, shorts, thin gloves.
- 4-8C: Thicker long sleeved top, or long sleeved top with light rain jacket (which I keep in my bag). Usually still in shorts, but with Leg warmers on (I mean the type that are like arm warmers only bigger. Nothing that makes me look like an extra from Fame!). Winter Gloves.
- Below 4 degrees: Full winter gear - Jacket, long sleeved top, full length bib tights (which have a fleecey inside), overshoes (even if it's not raining because otherwise toes get cold), winter gloves, head band thing to cover ears.
Always carry:
- Your lights (and spares).
- puncture repair kit and inner tube (and small pump!)
- A light rain jacket
- overshoes (For rain AND cold)
- A spare pair of socks (One day you WILL need them)
- some kind of lock (even if you have storage facilities where you're going - you may need it if you have to stop at a shop or have a mechanical problem)
Finally:
- oil your chain every few days (more if it rains) and...
- CHECK YOUR TYRE PRESSURES WEEKLY.
Ignore those two points and you'll expend a noticeably higher amount of energy simply overcoming friction!
-Don't forget you will need to service your bike a lot more. I change chains roughly every 3 months, then the cassette every 4th chain (although I do this 5 days a week, so you should get longer)
Sorry it's a bit verbose. Hope it helps though. And good luck!
steve52
I'm back! Yippeee
if carrying a laptop, a good drybag is esental,ie a drybag inside the pannier or rucksack, and i would use a marine standard,
wiggydiggy
Definately 'see with' lights but do please angle them - I pass a few riders on my cycle path commute that have no consideration for half blinding you!
Other than that everyone has covered everything, and I remember the Speke underpass - I picked up my bike and carried it for 1/2 mile or so the glass was that bad!
S
sabian92
first of all, no 22 mile journey is flat so he prepared for some hills. I started off with a 17 mile commute and it frickin hurt for the first two weeks... And i thought it was "flat".... so be prepared for that. Get thro those two weeks and you'll be ok.
bike should have two lights back and front in case one fails. Get good lights for the trail, you'll need to avoid potholes in the dark. Make sure tyres are pumped and you carry appropriate inner tube, pump etc.
For body, depends on temperature. 3 layers does me up to 8 degrees, 2 up to 12 degrees, 1 layer if hotter than that, but you'll work it out. Thermal cycle tights, good gloves, skull cap under helmet will help keep ears warm. Wiggles own brand (dhb) is cheap and good. Carry a waterproof (or use as 2nd or 3rd layer) if you've got nowhere to dry your clothes in the day. If you have cycle shoes with cleats, get neoprene overshoes to keep feet warm/dry, if using trainers get waterproof socks.
try the ride on a weekend first so you know how long it takes.
most important... It will be harder than you expect the first time, but don't give up bcoz in a few weeks you'll be loving it.
Cheers for the advice, appreciate it. I know it'll be hard, and I'm trying to flog some stuff so I can get decent lights at the moment.
I have cleats (MTB ones, FWIW) so overshoes it is.
I'll just crack on with it and hope for the best I reckon. That's if I don't get lost!
I mailed the gym - welcome to use the showers, not welcome to store stuff in their lockers.
Arse.
400bhp
Arse.
Leaving there in the morn and picking up at the eve? How did you pose the question as I suspect they dont want things left overnight rather than left for 8 odd hours in the day.
S
sabian92
Hello, I'm a student at LJMU. I'm planning on cycling from home in Runcorn to Byrom Street each day and at 22 miles each way, I'm going to need a shower before I head into uni. Would it be possible to use the showers and leave a few items of clothing in a locker while I attend my lectures then collect them on my return? I'm not able to take my bicycle panniers into lectures etc as they only have a carry handle and not a proper strap for carrying over the shoulder.
Thank you, Andrew Williams.
Apparently they get busy during the day - I was clear but apparently no go. Bugger.
buggi
Bird Saviour
Solihull
get a microfibre towel. They take up minimal room and dry very quickly and are highly absorbent, that will lose you some carrying weight. Can you get a locker at uni that you could store some stuff in? Leave your shoes there?
400bhp
how would they know if you sneakily left some stuff?:whistle:
Aye, they wouldn't would they. They could only tell when the place is empty, ie at closing times.
Can you leave some stuff in a classroom/lecture theatre?
S
sabian92
Well, I spose they wouldn't, but I'm sure eventually they'll clock on to me coming in with 2 panniers wearing tights, mtb shoes and a jersey and leaving in jeans, hoodie and converse :laugh:
Not really... I change rooms etc and I wouldn't trust my stuff anyway. I go to uni in Liverpool, don't forget ;):laugh:
Origamist
Ride mainly at an even pace, stay relaxed, carry stuff on the bike (not your back), enjoy yourself, but be prepared for some days when you will feel psychologically down (wet, constant headwind etc) - either battle through it or take a day off from the bike. Good luck.
buggi
Bird Saviour
Solihull
;):laugh:
carry out a really heavy empty bag LOL i had stuff robbed from a gym once, so even they are not secure. Imagine coming back to no cycle kit :sad:
