MacB
- Farnborough, Hampshire
Ok, all priced to sell and including postage, I will be away on hols for two weeks from Thursday 12/8, pics of all items at Flikr, here:-
http://www.flickr.co...57622994429958/
This will be posted on CC, YACF and CTC, first come first served, I can accept direct bank transfers, Paypal would need to be gift or you take charges. All of these prices are sub 60% of what was paid for the items.
Seatposts x 3 all 27.2mm -
SOLD £8 - Thomson Elite Inline 2 bolt adjustments, all black, has been cut down to 220mm, very light
£5 - Giant A3 approx 25mm set back, single bolt adjustment, very lightly used, 300mm long, black with silver clamp
SOLD £5 - Bikehut inline 2 bolt adjustment, all black, 370mm, has been very lightly used, has one visible scratch from insertion
SOLD £7 - Seatpost Clamp - Hope Red 31.8mm, never opened, got wrong size and forgot to return, can't find receipt so flogging cheap
SOLD £10 - Titec L Bend bar ends with tubular foam grips fitted on them, part of my handlebar experiments and very lightly used
Stems x 5 all 25.4mm Bar Clamp and 1 1/8 steerer fitting -
SOLD £8 - BBB Highrise ahead stem, 90mm and 35 deg rise, 4 bolt clamp plate, all black
£4 - Unsure of make has a fancy S? on clamp plate, all black, 100mm approx 25 deg rise 2 bolt clamp
£4 - Tioga 90mm, 20 deg rise, black with silver clamp plate, 4 bolt cut away design
SOLD £4 - System X, 60mm with 35 deg rise, all black and 2 bolt clamp plate
SOLD £4 - old Shimano canti brakeset with preset straddle wires and fixing bolts, pads look in ok nick
SOLD £4 - unbranded v-brake levers, black and silver, used, suit smaller hands
SOLD £12 - pair of 9 speed triple shifter pods black with indicator windows, come with cable inners and outers - these are the pods that I filed out the inside of the clamps to fit on to the tops of drop bars. They will still work on flat bars though you may want to put a bit of tape under for a snugger fit. They work on drop bars as well, obviously, I don't promise that they are totally free of my blood following the filing work!
Handlebars x 4 all with 25.4mm clamp sections and take MTB not road controls -
SOLD £10 - BBB Butterfly trekking bars, black
SOLD £10 - M Wave Butterfly trekking bars, black
SOLD £10 - Northroad style cruiser bars, silver, very lightly used
Wall Mounted Bike Hanging Hooks x 5 -
SOLD ALL 5 £22 - the Wiggle Lifeline ones with the screws, I used a No 8 drill bit and rawl plug for masonry when I hung them. The plastic protective sheaths are useless. They're either not needed or you can put some surgical tubing on instead, far more hard wearing.
Available Again - £180 posted or £160 collected - SRAM I-9 Hub gear rear wheel, with all fittings, shifter and manuals etc. Silver hub 36h built into Mavic A719 black rim with silver spokes. Can run disc brakes with standard 6 bolt rotor mounting, has been run with v-brakes. Rim is in excellent condition and wheel is true, the hub internals were replaced, under warranty, by SRAM earlier this year. It has done about 120 miles since then.
