BADGER.BRAD
- Shropshire
A friend of mine ( new to cycling) asked me why his bike has so many gears (24) and then went onto explain he only ever had 3 gears on his various bikes as a kid. With this in mind I decided to convert my lads hack single speed mountain bike back to gears, As I had converted to single speed ( the complete gear train was trashed) by separating two cassettes and using the spacers to align the chain wheel and sprockets it was easy enough to use the same principal to make it a 3 speed. I tried to make each gear change a fair jump from the next and have settled on 42 teeth at the front and 24,17,11 at the rear. We used the front gear change lever ( friction type) and had to use a gear change cable with the an outer cable the full length of the cable as My lad had knocked all the cable stops off on the single speed conversion! with a quick adjustment it all works and the jumps between each gear are smack on. My commuter only has 8 gears and I only ever seem to use top or bottom for any length of time. The daft rainy day experiment seems to have worked well the only small problem I have is the chain jumps in top gear if you really give it some stick whilst riding up hill ,obviously a result of the whole drive train being a combination of nearly dead parts from different bikes (the chain is made up of two old chains).
Anyone know how much of a jump a Sturmey archer 3 speed gives between each gear ?
In terms of the jumping, just make sure it isnt a tight link where the chains have been joined. As far as the ratio's , sorry but I aint got a Danny LaRue
