30t or 32t N/W chainring 104mm BCD
ChrisEyles
Devon
I'd like to pop a proper single ring on my "new" MTB since I'm enjoying the pseudo 1x8 set-up I'm currently running with a locked out FD.
Would have to be a 30t or 32t ring since 8 speed cassettes are limited in max sprocket size to 34t and I'd like to be able to go up hills!
Wouldn't mind trying out an oval ring, but round is fine. Integrated female threads would be very nice since that's what my current set-up has so I wouldn't have to buy new chainring bolts.
Black, silver or blue in colour would be ideal, steel or alloy both fine.
Sharky
Kent
A quick search on amazon comes up with some for about £13
ChrisEyles
ChrisEyles
Devon
@Sharky thanks for that, didn't even think to look there.
@fossyant I'm dead curious how much (if any) difference they make. One thought that occurred would be if you're on a SS you'll have to push a higher than usual gear to get moving (when the cranks are near horizontal) - not good if you're starting again on a slope! Wouldn't mind trying them out just for fun.
ChrisEyles
ChrisEyles
Devon
I'll be sticking with 1x8 so no problems there - just interested since the oval rings seem to be marketed at SS low rpm grinders.
In an ideal world (with the chain wrapped around 180 degrees of the chainring) I think the tension on the chain should remain constant throughout the rotation of an asymmetric ring. In reality I guess you would need a decent chain tensioner to use for SS. If you're riding fixed off-road you probably have bigger problems to be dealing with ;)
ChrisEyles
ChrisEyles
Devon
Found a nice looking 30t (swanky blue) one on amazon for £20 which would do the trick nicely if no ones got one collecting dust in the shed (for the cheaper 32t ones I'd need new chainring bolts so not much in it and I'd rather a 30/34t low gear in any case).
