7 speed cassette
my current 7 speed cassette ranges from 11 to 28 but can you buy a cassette where the gear range is more compact say 11 12 13 14 16 18 20 for example
4F
Suffolk.
Theres a 13 - 21 here http://www.sjscycles.co.uk/shimano-hg70-7-speed-cassette-prod299/
Ratio:
- 13 / 14 / 15 / 16 / 17 / 19 / 21
busdennis
busdennis
been trying a few local TT before i join a club, not sure if im 50 or 52 up front but im consistantly changing from 11 to 13 and back again on the rear so i could do with a 11 12 13 combo then what ever
curzons246
derbyshire
I've got a Shimano Hyperglide 7 speed 12,13,14,15,17,19,21 very little use, it came on my Dyna Tech but was no good for Derbyshire hills - any good to you?
albion
Gateshead
As above, you can have HG 50 in 12-21 or strangely 13-23 or 13-26 only.
Consider moving to 8 speed.
busdennis
busdennis
hi all
dont want more gears, just some lower gears
and i dont want to be in 13, its just that im not fit enough yet to do the full course in 11 and i have no 12thats why im looking for a combination with 11 and 12 (but i dont think a combination of 52 front and 13 rear is too shabby for a beginer anyway)
albion
Gateshead
Obviously you have to buy 12-21 and change the front chainwheel if you want that high ratio kept, possibly the same for 8 speed.
I suspect 11T is not ideal and so for mountain bikes with small chainwheels.
albion
Gateshead
I meant to manufacturer but that is probably 10T. I also recall reading that 11T is less efficient than 12T due to power transfer problems on smaller sprockets.
Maybe it is manufacturers 'moving us on' with 8 speed and less now designated for leisure riders.
I slightly recall my old 8 speed cassettes had a cluster of something like 5 with the smallest 3 a separate piece.
My new ones have a cluster of 7 with only the 11T being a separate piece.
Historically old style 7 speed freewheels started at 13. 12T is rarer and 8 speed deemed problematic.
