700C Disc Specific CX Wheelset
Can any CX'ers recommend a good set of CX wheels with disc rotor options (either centre lock or 6 bolt). Will probably run a 35mm tyre on them. Standard QR axles front and rear. I prefer clinchers to tubs. Budget will be around the £500 mark. These will be for a build it yourself CX bike project.
Thanks.
Apologies for the multiple entries - if there is an Admin person about can you delete the ones that don't have this message in. Kept getting a timeout error message so assumed the others hadn't posted.
Click the "report" button on offending posts.
Spinney
Bimbleur extraordinaire
Back up north
Done - something not working with the software at the moment, I think. I've just had to delete a couple of my own posts that I managed to post several times!
Andrew_P
In between here and there
Thanks.
I think at the moment I would go the hand built route for disc brake wheels. The choice will improve once they bloody settle on a standard!
I have DT Swiss 240s hub with ZTR Grail rims. Seem ok 20mm tubeless compatible rims so would be ok with 35mm and you could run them tubeless or clincher
http://www.stradawheels.co.uk/product-category/cyclocross/ not used them but gives you a feel for what's out there
ayceejay
Rural Quebec
Williams wheels are in the states but they are offering free delivery at the moment. They make excellent wheels and the CX specific are excellent quality and value.
smutchin
Cat 6 Racer
The Red Enclave
Stan's Grail
http://www.notubes.com/ZTR-Grail-C170.aspx
Or, if you want more of a dedicated CX wheel:
Stan's Iron Cross
http://www.notubes.com/ZTR-iron-cross-C171.aspx
