My Genesis Croix de Fer was supplied with "Continental Cyclocross Speed" 700x35 tyres which worked fine when I was using it on-road but now I've branched out (sic) and added a bit of mud, leaves, gravel, tree roots etc to my commute, I fairly frequently get punctures especially when the ground is wet.
Can I get a more resilient tyre for these conditions or should I expect to get a flat every fifty miles or so when I'm riding on wet mud under trees? Looking at the most recent hole there seems to be no kevlar or any kind of protective layer in the tyre itself so I'm hoping for a better solution than "well, don't do that then"
32-35mm (the present tyres only just fit under my mudguards, so certainly no wider), preferably enough tread to make the offroad bits feasible but not full-on knobblies because I also like to go fastish on tarmac.
