Got a bit of a knocking from near the chain, with each revolution of the pedals. It becomes more frequent on the smaller gear wheels. Any ideas as I can't see anything?
Have a look through this lot, found it useful in the past http://www.jimlangley.net/wrench/keepitquiet.html
I always start at the top and work down, you would be amazed at the number of times the noise is saddle related, good luck.
Finally sussed it out on mine, had similar symptoms... got worse on bad roads... brake cable hitting the top tube and annoying me badly! metal metal knock with each hole in the road...
