There are a row of LED lights (green and red) that flash every few (maybe 5) seconds.
Question being.........
Should they do this??
BTW since it was fitted (a few weeks ago) this is the 1st time I have looked at it so I don't know.
Thanks
Good to hear that....I was a tad worried.
When they go all red, you've 20 seconds to run !![]()
Out the door, where else?That is no help.....which direction do I run??![]()
Even if they are showing as working they may not be one of ours has been going wrong for months now.
No one is willing to sort it and no one will give any idea as to when it may be fixed.
yep there is an ongoing issue I think.
I know someone who had a nonfunctioning British Gas one and was a hell of a job to get it fixed involving multiple calls around the planet, long waits to call centres, hangings-up.
You'd think if there were so damn smart it could all be sorted remotely but it needed a visit and arranging that was a pig with no idea if the bloke would turn up on the day.
Personally I feel no need for a smart meter.
I could be tempted by discounts for smart energy usage but reckon such promos will be short lived anyway.
Question - if you should give in to the constant calls to get a smart meter, can you just unplug it as a customer and go back to the old system of reading your hopefully well positioned meters and sending regular readings online?
The one furthest from the meter.Which door??
We live in a posh house which has a front AND a back door
Non of these?Mine had a red light flashing for years and would not communicate with the energy supplier after I switched
When EDF magically upgraded the meter without visiting or informing me - must have been magic because before that it was apparently impossible - then the red lights turned green and it all worked again
Looks like it is a comms handshake and if the 'other end' is talking to it you get a green flashing light - if not it flashes red
As a retired IT geek I would like proper manual showing everything about it
but then again - I am probably the last type of person they want knowing about it!!![]()
