A Shiny Thing I Built: Look Upon My Works, Ye Mighty...
DRM
West Yorks
Well - it's both a surprise and a relief to get such positive responses to my little exercise in absurdity! Cheers! ^_^
Setup was really straightforward - everything goes together, adjusts & works as you'd expect. In the past I've found setting up SRAM to be less finicky than Shimano and this (being a total knockoff) appears to have inherited that - other than a couple of cable tension tweaks, nothing's required fettling since assembling it.
The bar tape is a bit odd! The pics don't do it justice though - it's colour-changing, iridescent & reflective, and changes from different angles & under different light. I've honestly never seen anything like it. Which may or may not be a good thing. It was a bit of a pain to fit - it's not particularly flexible & fairly thick and was impossible to get as tidy a finish as I'd prefer at the bar ends. It's also not a texture you'd want to hold onto all day (quite slippery) which it's why it's on the drops. Where I seldom am...
I watched his vids when doing research about the Sensah stuff - there's really very little info out there. As he said, the plastic actuating lever that's prone to breaking has been updated to a metal component - when I ordered, I was basically crossing my fingers that mine wouldn't be turn out to old stock, & fortunately they do have the uprated part.
I’m quite intrigued to see how this pans out over time, I hope you can keep updating the thread as time goes on, the bike looks really good.
Xipe Totec
Xipe Totec
Frrrg rrrrf yrrrr crrrnds
Will do - although I'll probably use it a bit less over the winter, so my old Boardman CX hack doesn't get jealous!
cyberknight
Xipe Totec
Xipe Totec
the pro wheel chainring on my commuter lasted a year , you can buy a new ring for a similar amount is all im saying
https://www.aliexpress.com/item/100...52545031-04066-UneMJZVf&device=c&gclsrc=aw.ds
As far as I can see it doesn't look like replacement rings are available for these RaceWork/LitePro/whatever AliExpress things - they're a single unit with both rings machined from a single chunk of alu & attached using that SRAM 3-bolt centre fixing. What's interesting is that my suspicions about its durability come from my experience with a Prowheel triple I had on a Decathlon Triban about 10 years ago - think I got about 3000 miles out of the rings on that, if I was lucky.
If they do turn out to be cheese I suppose I could use SRAM rings - but when replacement with cranks that look like this are available, why would I do that?
Actually, my mouse is hovering over the 'buy' button right now... :ph34r:
Dale 1956
Caribou, Maine
Wow nice build.I love building a new bicycle it makes me feel good.
Xipe Totec
Xipe Totec
This is probably due an update!
Not put a huge amount of miles on this as it has to share me with two other bikes & Zwift, but around 1100 miles later, the only cheapo original part to give up the ghost is the BB, the left side bearing having become rough & noisy approaching the 1000 mile mark. Quick & cheap to replace with a Shimano Tiagra.
Everything else still going strong & working properly, although the rear mech cable has needed a bit more regular tensioning than I'm used to. It's the original cable supplied with the mech so may not be the best quality & the heavy spring in the mech itself probably doesn't help. I have a spare in my toolbag but will replace it anyway, next time the bike gets an overhaul.
Aesthetically, the bling oilslick finish on the front bottle cage is flaking & the alloy underneath appears corroded - but that's cheap shiny rubbish for you. Likewise the ridiculous reflective rainbow bar tape on the drops has started splitting, presumably due to the material hardening & cracking where it's stretched. So that's going in the bin.
Otherwise all looking good, will post some pics once it's had a hose-down & new bar tape.
Xipe Totec
Xipe Totec
Oh wow. That's a funky seatpost indeed.
Is 80 a bit high for 32mms ? I'm running my contis at 50 on the front and 60 on the back. No issues with them in a few years.
