A sobering reminder (car prices)
Fastpedaller
Norfolk
I reckon a higher-mileage car is a good buy - if it has over 80k miles then it's not had short runs without the engine getting hot. Short runs kill an engine*. If it has less miles it could be that the mileage has been reduced (that's easier now with digital display than when the mechanical display 'clocked' gave mis-aligned digits). Google mileage 'correction', there are people doing it . I certainly wouldn't want to be involved in that.
* When I worked in engine design we had a test engine doing repeated cold starts - After 300 hours of testing the bores were ruined!
Pblakeney
In my experience once you get to around 120,000 miles they’re trouble!
I never had a problem getting to 150k when doing high mileage. My current car is at 120k. Hmmm. 🤔 But no issues.
Only 3 years to go for "free" motoring. 🤞
Jameshow
120k could be 3 yrs motoring!
Po refer a high milage car to a local use speed hump basher!
Also avoid cars from the coast the sea spray kills them damhik!
gbb
gbb
Peterborough
Having worked with many E Europeans who prefer German cars and are not put off by high milers, the one thing tou realise is while the engine will generally be ok, the higher the miles, the more cost you will face with fuel pump replacement, injectors, suspension componentry etc etc.
cyberknight
same goes for asian blokes from what i have seen , many at our place have a thing for audi.
  • Like
Reactions: gbb
Gunk
Oxford
From my experience of running high mileage BMW’s the engines are bullet proof, problems I’ve had over the years are as follows (petrol and diesel. Mainly 3 series tourings)
  • Coil packs
  • Blocked DPF
  • suspension arms
  • ball joints
  • suspension bushes
  • weeping shocks
  • VANOS issues
  • failed electric window motors
  • failed central locking module
  • failed Bluetooth module
  • split expansion bottle
  • split washer bottle
  • broken tailgate hinge
  • broken FM aerial (built in to rear glass window)
  • jammed seat belt
  • Uneven tyre wear
  • Failed CO2 sensor
  • Like
Reactions: gbb
Jameshow
  • Coil packs
  • Blocked DPF
  • suspension arms
  • ball joints
  • suspension bushes
  • weeping shocks
  • VANOS issues
  • jammed seat belt
  • Uneven tyre wear
  • Failed CO2 sensor
Basically a Whole BMW!!
Other brands are just as bad!!
gbb
gbb
Peterborough
VAG cars are far better
Maciej, a former colleague had a Golf diesel with iirc, around 270k on it ? (Bit sketchy memory, it's a few years ago now).
He had no problem spending on it, he commuted around 100 miles a day, 4 days a week so wanted to keep a car he knew and trusted. Nevertheless, he was servicing (oil and filters) around 3 times a year, had the injectors done, cam belt or chain, multiple brake jobs, various suspension bits done, abs pump etc etc. It was a pretty penny in costs but as he said, buy another used car, you don't know what you're getting.
It didn't make 300k, something else went wrong and he sold it as a runner but needing work.
Disappointed slightly he didn't make 300 k but he didn't have a problem with running costs at all. Different mentality to us here...
Pblakeney
If he is anything like me then the running costs are much less than purchasing costs. To a point.
  • Like
Reactions: gbb
rivers
How far can I go?
Bristol
We just bought a new to us used car to replace our aging 09 Kia Picanto. We bought the Picanto in 2014 with 19000 miles on the clock for £3400. An equivalent model that is 5 years old going for £4k has 100,000 miles on the clock these days.
We just spent about £2k more than we wanted to to get a 2018 Kia Stonic. But mileage was good for the age and it has all the bells and whistles, so can't complain
