Do I actually need to use these, as it seems to my novice brain that they will just get in the way when it comes to removing the wheel? I would have assumed that just properly torqued track nuts would be sufficient. So what am I missing?
View attachment 130783 I have a relatively silly question. For a fixed build I am starting on, the frame came with adjuster screws on the track ends.
I thought they kept them level when tightening the chain.The screws keep the wheel level in the track ends,eg when replacing the wheel
You would just loosen then I assume...like on a motorbikeBut you can't push the wheel forward to slip the chain off?
Shaun
