Advice on converting vintage French frame to SS
lugless
I have an vintage French frame Meral with BB intact and rear Maillard wheel with cyclo 72 freewheel (5 speed cogs).
I would like to convert this to a single speed and have a few questions.
Can I keep the Cyclo 72 freewheel and adjust with spacers or is there an easier/better alternative ? What information do I need to be careful of before buying a crankset ? Are all square taper crank fits the same ?
Before rushing out an buying some bits, a little knowledge might be a good idea.
gaijintendo
Scotchland
Your bottom brackets come in a variety of widths to suit the cranks on them. I was just looking this week and noticed the options 103mm 107mm 110.5mm 113mm... I suspect these don't change the chainline, just position the cranks correctly. As for the back end... Not sure.
As an aside... I'd love to see the frame.
raleighnut
It's a freewheel (not a 'freehub') so just unscrew it and screw on a single speed freewheel, you may need to adjust the chainline at the crank.
L
lugless
Thanks for the responses. The first step will be to order a removal tool - just looked at prices ... ouch !!
I will upload some pictures soon. Other than the makers decals it has no tubing identifiers.
midlife
If you don't want to keep the freewheel there are ways of removing it without a tool....have you got access to a vice?
raleighnut
If you work out what size single sprocket freewheel you need and buy it from a shop chances are they'll swap em over for you, my LBS would.
L
lugless
si_c
Wirral
Would a suntour two pronged freewheel tool fit the freewheel?
Also, why not get a new wheel with flip flop hub and keep the existing wheelset as spare in case you want to go geared again later?
L
lugless
I think the replacement wheel with Flip flop hub is a good idea. I decided to convert an old Raleigh to singlespeed as a warm-up project. I can then try the wheel from that on the French frame and see what compatibility problems I hit as I try components at hand.
