slowmotion
Quite dreadful
- lost somewhere
I assume the camera isn't far away from the Laptop - signal can deteriorate with analogue quite quickly over a number of metres. How does the current video camera record - DVD, memory card or tape ?
The other option is to leave it recording and edit later on the PC ! I have an old Dazzle AV unit for the PC that worked well, but it's way out of date now (for a video tape camcorder) My son uses my FIL's old Sony DVD camcorder, and then converts the DVD format to MP4 on his computer rather than use a USB/AV INPUT stick we have been given.
The camera is based on the Sony Effio 4140 mini camera. Here's the board, about 35mm square. Amazingly, you can manually focus the lens.
You suppy it with 12 volts and it has a Composite Video output that comes back on a screened lead with an RCA plug on the end. There is a second RCA plug that gives an Audio output. The images and sound come back in real time. There is no storage unless you supply your own device. I have plugged it into the Video and Audio Sockets on our TV and it gives good sound and vision, so signal degradation by the cable is not an major issue. When I tried a cheap Video to USB convertor, I can get images on my PC that I can store on the hard drive etc. and manipulate, but the picture quality is not nearly as good as the TV. I'm trying to find a way of getting better pictures and moving images on the PC by any other route but at no great cost.
