Advice on servicing headsets
I never bother unless I get a problem. If it ain't broke....
gbb
Peterborough
Its quite easy and can lengthen the life of a bearing.
I do it at work more than on the bike, ie repairing an assembly and find i dont have a new replacement bearing. Seals out, clean, as he says blast out with an airline , pack with grease, insert seals and refit.
Done it on crank bearings a couple times. Ive even done it to some pretty dry and dirty bearings, it can have quite an effect.
jay clock
jay clock
Massive member
Hampshire UK
Thanks everyone. A new headset is £15 so I think I will stick with occasional replacement
I like Skol
A Minging Manc...
Am I missing something here? Unless you pop out the seals and repack the bearings then why the heck are you servicing the headset?
In fact, I'll change that. Unless you repack or replace the sealed bearings then you are not actually servicing the headset, you are merely taking it apart and putting g it back together again.
Either leave the bearings until they are shot and need replacement or repack the bearings. Anything else is just fannying about and you risk damaging something (stripped thread or similar!).
jay clock
jay clock
Massive member
Hampshire UK
Thanks. By taking it apart I did manage to have a good clean up which must have helped
