The piccie below is my DiaTech aheadset on my 10 year old mtn bike. It's 1 1/8, though until recently I thought it was 1" but that's an aside.
I fitted a new riser stem to it and in the course of doing it was a bit surprised. I've never taken the headset apart, had it done at a service a few years ago but 1st time for me.
So. The grey rubber cover you see is a bung. There's no hollow bolt or star nut for adjustment underneath. When you take the stem off, the forks drop down. It does have a collar below the stem which is tapered, top narrower, bottom wider and that fits onto a tapered spacer to match.
To put it back together I had to tap the stem down and force the collar onto the spacer. I then notched up collar and stem and checked it all. It seems OK, not too tight and no slack.
So my question is, as I need to take it apart again for a clean and grease, what's the technique, in particular what do I do with that collar?
