Annoying rattle that disappears after a few miles
Discussion in 'Bicycle Mechanics and Repairs' started by Roadhump, 18 Jun 2017.
  1. Roadhump
    Roadhump Time you enjoyed wasting was not wasted
    I wonder if anyone could advise on this please.
    I have a 4 month old Giant Defy and have ridden about 800 miles on it. It feels good to ride and the brakes and gears work well. A while ago I noticed a clicking that sounded like a double click every second revolution of the pedals, but it went away after a few miles. I recently had the bike serviced and told the mechanic about this. When he returned my bike he said he thought the clicking was probably my foot knocking a cable end, which had lost its cap and become frayed, and knocking it against the mech. He tidied this up and put a new cap on.
    However, I have since ridden it 3 or 4 times and the clicking is now worse, it is now like a constant rattle, but again disappears after about 3 miles, it is as though it is like a car that sounds rough until the engine gets warm then runs smoothly. It happens when pedalling and freewheeling, but seems to reduce when I use the rear brake. I thought it might be the spokes, but the mechanic should have tightened them when he trued the wheels (which he said he did), and when I have checked them there are no loose ones.
    I suspect it might still be something to do with the spokes though. The wheels are Giant PR2s, which have had some mixed reviews, such as those in the link below. I don't want to go through the inconvenience of taking the bike / wheels to different LBSs or mechanics if I can avoid it by getting more of an idea, as it might not be the spokes, and for the same reason, I don't want to go to the expense of just changing the wheels.
    http://forums.roadbikereview.com/giant/giant-road-wheelsets-info-weights-263876.html
    Any help / advice gratefully received, thanks.
  2. Heigue'r
    Heigue'r Über Member
    Upminster
    Ive got pretty much the same thing.I have narrowed it down to the saddle rails...thought it was wheels or bottom bracket but it is 100% my saddle rails...it does disappear after a while also however that works...have you tried pedaling standing up and is the click still there?
    Roadhump likes this.
  3. berty bassett
    berty bassett Veteran
    I'boro
    after trying standing while pedaling try hooking seat on washing line and turn pedals by hand - change into all the gears- if it has got worse then it is something thats been tinkered with - even clip shoes in and turn pedals (take them off first );) if it is a rhythmic click then i would guess something to do with crank ,pedals ,chain or you catching something - if its a click thats all over the place maybe bearings somewhere -if it don't happen at all on washing line could it be handle bars ?
    aint clicks annoying !
  4. "A double click every second pedal rev" could be a stiff link? The click would be the link passing through the mech. In the big ring it would be a tad slower than every second rev.
  5. Sharky
    Sharky Veteran
    Kent
    If you are satisfied that the bike is safe, then perhaps just live with the noise. The more you listen/observe, the more you will be able to pin point where it is coming from. If you think it is the rear wheel, do you have another bike/wheel which you could swap over and see if the noise stays with the bike or goes with the wheel?
  6. An aside, I distinctly remember years ago riding along happily in the sunshine thinking, "that click is a bit odd, it's not in time with my pedalling and it's not in time with the wheel revolutions, oh well, not to worry". Shortly afterwards my chain broke.
  7. OP
    Roadhump
    That is a great idea, why didn't I think of it? It just so happens that I have another bike with Shimano 105 11 speed rear cassette, which is the same as the Defy so I will try that. Cheers.
    Sharky likes this.
  8. OP
    Roadhump
    Couldn't you just use a bike stand instead of a washing line?
    berty bassett likes this.
  9. gbb
    gbb Legendary Member
    Peterborough
    An extremely unlikely cause...but one that flummoxed me for ages....have you a spoke protecting disc fitted ?
    My wife's bike suffered an irregular click, noise, squeak kind of thing, after loads of investigating various causes and ultimately riding alongside her with my ears cocked...it's coming from the hub...:huh:
    I don't remember how I identified it as the plate but took it off...noise never returned. It must have been rubbing on the spokes or as the spokes loaded and unloaded their tension, it flexed the disc....or something like that :wacko::laugh:
    Dogtrousers and Roadhump like this.
  10. Red17
    Red17 Senior Member
    South London
    Had a clicking issue with Giant wheels recently. Turned out to be the rear cassette lockring was only hand right which was causing the clicking when under load so possibly worth adding to the checklist
    Tom B, gbb and Roadhump like this.
  11. OP
    Roadhump
    I took up the suggestion from @Sharky this evening and replaced the rear wheel with another one the same size and with the same cassette. The noise was not there, and after 8 miles the noise had not occurred. I returned home at that point and changed the wheel back to the original and the noise returned. It took about another 7 miles to disappear. I therefore feel quite certain that the noise is caused by something to do with the rear wheel. I am a bit cheesed off with the mechanic who really have picked this up and corrected it, especially if he trued the wheel, as he said he did.
    Sharky likes this.
  12. Sharky
    Sharky Veteran
    Kent
    It's a puzzler!
    Does sound as it the problem is in the wheel, but I can't think of anything that would make a noise for 7 miles and then stop.
    You could try swapping the QR skewer with the one from the other wheel. Unlikely, but is an easy test to do.
    Hope you find the cause,
    Keith
  13. OP
    Roadhump
    Thanks, I'm off on my hols for a fortnight tomorrow so I'll try and sort it out when I get back.
    Sharky likes this.
  14. A wheel builder will probably laugh and tell me this is a silly meme but ... Years ago I had a wheel trued and it was making sploinky noises so I lubricated the spoke crossings which seemed to sort it out.
  15. Ajax Bay
    Ajax Bay Veteran
    East Devon
    There are 3 rhythms on a bike: cadence, wheel turns per minute, and for want of a (better) name: chain completions per minute. The last is related to the first (well of course they're all related) but for creak/noise frequency analysis, along a flattish road going steady, a rider does about 3 turns of the cranks per chain completion.
    Dogtrousers likes this.
    Dismiss Notice
