Globalti
Does this cassette look worn to you?
Ultegra 10 speed on Roubaix SL4 with internal frame cabling and "hidden cables" on the bars.
Here's the problem: the shifting on Ultegra "hidden cable" shifters is pretty poor. Mine work acceptably as long as the cable outer at the derailleur is brand new but after 100 miles or so it all goes to pot. I'm using Shimano inner cable and there seems to be no performance difference between Shimano outer and Jagwire outer. I change the outer cable often, always grind the ends flat, everything is clean and correctly adjusted yet after a couple of rides, I'm having to over-shift to get the chain to move up the cassette and sometimes it's sluggish dropping down. It's worse on this bike than the previous bike, which had the same Ultegra hidden cable shifters but exterior cables on the frame. It's driving me mad, so much that (shudder) I'm even considering handing the bike to a shop mechanic to see if I'm doing something wrong.
The chain is almost new and here's a pic of the cassette. Could tooth wear be affecting shifting? Even if it's worn, that wouldn't explain why the shifting starts good with a new cable outer but all goes to pot after 100 miles or so.
Any ideas?
Any ideas?
