Hi everyone
Sorry to bother you all again with my bike troubles.
I decided in my wisdom to inspect the rear wheel as I wanted to sort out the disk rubbing on my bad boy, that done I thought I could feel some play in the hub, so I removed the wheel and quick release and spun it whilst holding either edge of the axle it was smooth and noise free.
I did notice however that I was able to turn the locknut on the end with my fingers !?. Is this a problem should it be super tight against the cone or is it ok that its sort of finger tight ?.
I understand that you need a little play with the wheel out and not under the pressure of the quick release but didn't know if I need to use a couple of cone spanners and tighten the locknut without moving the cone ?.
Its not as if its going anywhere as when its in the frame and tight the locknut cant turn and no play is present at all but its sort of got me worried
