swee'pea99
Ok, new plea...
I fitted the new unit, by simply using one of those electrical wire-joining strips, matching up the wires by colour. Installed, working, fine. Hoorah. Except...the radio wouldn't work.
Realised what I'd done - attaching all those wires, I'd forgotten to connect the aerial connector. Idiot!
So, removed it again, connected the aerial, decided to check it before re-installing it, nothing. Dead as the proverbial. Checked the connector strip - sure enough, the yellow power cable had detached itself from the strip. No problem. Re-connected it. Still dead. Uh-oh...
I've now rechecked all the connections; they all seem sound. Two of the power leads had fuses on, checked those, fine. Still nothing.
I've been using a multimeter, going back to the original power source cables inside the audio housing space - before all the connectors and wires - but there doesn't seem to be any power at all.
I'm no expert at this stuff (can you tell?) but the way I've been doing it is to jam one of the multimeter pins into the (red or yellow) connector, and touching earth (the door hinge) with the other. That should show a 12v charge +/-, shouldn't it? But nothing. Not so much as a flicker.
I'm really baffled now. I could understand if I'd screwed up the connections, but no power at the source? That just doesn't make sense to me. Does it make sense to anyone else?
And advice/suggestions much appreciated.
