ClichéGuevara
- Kingston upon the River Hull
If it's the same company, there's two not far from me.
It's Yorkshire Water.
One board member lives not far from Huddersfield Royal Infirmary.
I'd say you're going to hire a meter and bill the cost to them.
Not uncommon for a single supply pipe to branch and feed more than one house.
(our leccy supply does something similar and branches off to next door before it arrives at our meter).
Don't know whether to believe it, but I once heard of a house with an "over-enthusiastic" water meter caused by air bubbles in the main; the house was at the top of a hill, so bubbles would be pulled through the meter and drive it mad.
Worth considering if you ever see airbubbles spluttering out of your cold tap!
If there's a leak and the meter isn't on the property, it'll be measuring any water that may be leaking. Or if there's a joint after the meter.We're not on a meter, but I was curious about how much water we used. I thought it might have been worthwhile to get billed by our consumption rather than the rateable vale of the house (or whatever it's called). You can buy your own water meter for about £30, and it's a doddle to plumb it in where the main comes into your house. I would do that, and compare it to the water company's meter. It could be a leak between the company's meter and your house, or it could be that "your" meter is being used by other properties. If you have a meter in your house, you will know which.
I think it's pretty unlikely that a meter will over-read, BTW. It could of course be that the meter reader can't read a rotary dial meter.
Can you get your mum a big supply of bottled water and then turn the valve off at the meter? I would imagine sometime relatively soon after this the water company will start getting calls from someone who's tap has stopped working![]()
What about something like this?If there's a leak and the meter isn't on the property, it'll be measuring any water that may be leaking. Or if there's a joint after the meter.
They've(YW) not got a good record when it comes to finding leaks. And most of their maps are out of date by over a quarter of a century.
If they think someone is getting free water then it's up to them to find out who and sort it PDQ I would take the view that anything over what a normal one or two person household uses means your mum has been over charged. Maybe for years.
That sort of thing is not uncommon. We had a meter fitted donkeys years ago when we paid water rates as a percentage of your council rates. We actually paid them to install it in the path outside. Job done and I had a look. Very neat but................the meter wasn't clicking over. Made a note of the numbers (close to zero anyway) Check again a few days later and ...............the number was the same.
So a decision had to be made, free water, or get them back. Well I knew the free water option would eventually come back to bite me so I called the water board.
''No, no you must be reading it wrong sunshine, it's the black and red numbers on the dial'' After a bit of argy-bargy it was agreed a 'bloke' would call round.
Two weeks passed and said 'bloke' turned up. Much scratching of head, taps on and off, calls from the house phone. Another vist by about 5 'blokes' all stood around and looked at the non functioning meter muttering. Two weeks further on a crew turned up and dug up the path again.
It seems they had put the meter on a disconnected pipe. The live one to our house was about 18'' to one side. So they fixed the meter onto that instead.
Years later whilst refitting the kitchen I found a cut off gas pipe in the corner of an old cupboard. Plugged with an old rubber hot water bottle cap.
Took it out and sure enough it was still 'live'
The gas board obviously thought I was an idiot but did send someone round 'just in case'. Once he tested it there was an almighty panic to get the pipe capped off and to discover how it could still be connected.
The drive was dug up, as was next doors and the pipe was being fed from next doors mains feed. Who disconnected it in the cupboard in our house and stuck a rubber stopper in it is anybody's guess.
But I keep thinking of all the years of free central heating we could have had if only I had kept schtum.
