Any window fitters here ?
clid61
The North
I bought a house recently and the downstairs batroom window ( sealed unit } wont open. No key fits , the lock appears to be jammed shut any pointers please :smile: Can post pic if needen
Try this hopefully the internal window mechanism isn't Broken
View: https://www.youtube.com/watch?v=vJvshk0boXU
Adam4868
Are you sure it's the lock that's jammed ? If it's the spindle you could take the handle of another/same handle and try it...or if the window has jammed shut run something down the seal/around the frame to get it moving ?
slowmotion
Quite dreadful
lost somewhere
If nothing else works, drill out the barrel of the lock starting with a 5mm dia. drill and using progressively bigger bits until it disintegrates. You can probably get a replacement lock somewhere but it isn't the end of the world if you can't.
Milkfloat
An Peanut
Midlands
Those locks will open with just a flat head screwdriver, usually causing no damage at all. I lost the keys on mine many a year ago.
The pins that are activated by the handle slot into plates on the window frame. These can get corrided/oxidized and can be a right b****r to release. Hard to get at them. You can easily break the handle if you try and force it.
irw
Quadricyclist
Liverpool, UK
Well that's your secret identity out the window...err, or not...!
