Drivers should all be listed on HP's website (you obviously have internet access
). You'll need the exact model number (G6000 is just the chassis number) which will be on a sticker on the underside. There may be a folder in your C: drive called 'Drivers', that would contain all the installation files for the original set of drivers.
There are very few PC'sNotebooks that come with Driver discs now, most require you to make a recovery disc when first set up but that wouldn't solve your issue anyway by the sounds of it.
TBH, once a machine starts to BSOD, you're looking a a full restore to make it stable again. The BS should tell you some of what the cause was, what does it say?
