Anyone got access to a lathe
Phaeton
Grumpy Old Barstool
Oop North (ish)
Looking for some bushes/sleeves/tophats to be turned on a lathe, fairly simple job just don't have access myself, rough sketch attached, need to firm up the dimensions once I know I can get them made, can be mild or stainless steel, or aluminium, I need 8 of them
569848
If you can get the search terminology right you’d be surprised what you can get on eBay pre manufactured. Does it have to be that exact size? For example I needed a sleeve to put in my frame to accommodate a 25mm seat post in a 28mm hole and the solution cost 48p from Toolstation being a 28mm Speedfit pipe insert.
Phaeton
Phaeton
Grumpy Old Barstool
Oop North (ish)
The 16mm is fairly critical as that does go into a hole, the 8mm could be 10mm, the 25 could be 30, the 3 could be 5, I ave found a guy on ebay who makes sleeves & sent him a message but waiting for a response.
Edit:- @sleuthey on your suggestion I searched for 'custom lathe' found another couple of people so sent them messages Thank you
slowmotion
Quite dreadful
lost somewhere
Scratch around on the internet using "flanged bush" or "top hat bush" as search terms. I'm pretty sure you should be able to buy something off the peg but it may require a bit of sleuthing. Good luck.
Dirk
If 6 Was 9
I sold my lathe and milling machines last year, otherwise no probs.
Phaeton
Phaeton
Grumpy Old Barstool
Oop North (ish)
That's amazing. I may have to PM you to get the details in the not too distant future.
By all means, I sent him the rough sketch from above as it was 14mm not 16mm & I need 8mm clearance not 8mm,
Thats a good price from an individual or jobbing shop, it is about what I would charge, take their arm off for it if they agree.
Yep he agreed, expecting delivery any day soon, from what they guy who gave me his details said was he's a retired engineer keeping his hand in in his shed
slowmotion
Quite dreadful
lost somewhere
You are extremely fortunate to have found him. Well done!
