swee'pea99
Most pumps have a big chrome centre key, with a flat slot. If you remove this a bit of water will come out, but you can see the motor spindle. It should be spinning. If it's not, something is jammed in the motor or the motor itself has seized. Lock off valves either side of the motor for removal/replacement
Looking at the direction of the Motor, the chrome key is facing the cabinet side on the left, difficult to access. I would loosen the fittings and rotate the motor so you can remove keyto check motor rotation
See images https://www.google.com/search?q=cen...=_d4fEY7XfGLTE8gKl4474DQ_31:22.85714340209961
The interesting keeps coming! Many thanks.
Managed to get this:
...which clearly shows the 'chrome key' you mention. How do you actually go about removing it? (I can definitely get access to it one way or another, even if it means cutting a chunk out of the MDF.) Does it just screw out? And was I right in thinking that if I shut off those big red & blue taps, I can then work on the pump without fear of a full on flood?
Thanks again.
