chug666
Hi all,
I'm building a croix de fer as a do it all bike and having read a bit on the pros and cons of pre- build frame protection I thought I'd give it a go. Went for waxoyl aerosol because I had some in the garage and it gets as many mentions as other options. My thoughts on the process:
1. It is messy! I tried heating up the can of waxoyl so it went on a bit less clumpy (put it in a measuring jug of hot water) and that possibly helped, but it still went everywhere. Easy to wipe off mind.
2. The bendy plastic tube to get into angles isn't that bendy. Felt like most locations it went straight in, so only the metal immediately alongside each hole got a decent blast.
3. It is impossible to see how good a coverage you achieve. I mean you could dissect each tube, but that would be inadvisable.
I'm letting it dry before I pass further judgement. The whole process didn't take too long and I'm glad I've done the seat tube, bb shell and fork head tube, but the rest felt a bit hit and miss. I guess if I strip the bike down in a year or two and it's rust free it will have been worth it!
Interested to hear from any other waxoylers, and how your technique differed from mine...
