Are my chainrings worn?
bigfella
Essex
Just bought a new bike that I'm cleaning up and making good.
I had to drill out one of the chain ring bolts which was a bit of a pain. Is the larger chain ring too worn to reuse?
Thanks.
MrGrumpy
Huge Member
Fly Fifer
well from my experience gear cogs should be ok as long as they are not hooked, your ones from the picture look worn tbh.
Globalti
It looks too worn. Put a new chain on and try to lift a link off the ring; if the rest of the chain moves around the ring there's too much space between the teeth.
Steve Austin
The Marmalade Kid
Mlehworld
Looks alright to me. I would use it
Only problem with using a worn chainring is it can wear a chain quicker. but tbh, unless you are planning on doing 20k on if this year i wouldn't worry
longers
If you end up replacing it, can I have it if I pay the postage please?
Deleted member 1258
I agree with that, it looks totally cream krackered, I'd change that as soon as I could, what state is the rest of the transmission in?
B
bigfella
Essex
I checked that, the cassette is absolutely fine. I assume that the bike was built with part used components.
