silk186
- Reading, Berkshire
no "Select Option Pair - Right Hand Front/Left Hand Rear"
Thanks, that's what I wanted to know. Do you know if their is a noticeable difference between different rotor sizes?Hey Silk. I am still running the original Tektro (crap IMO) rotors on my hybrid commuter and have covered over 10,000 miles on them in all weathers. I did skip the original Tektro brakes after 2000 miles due to them being utter junk and replaced with Shimano XT which have performed almost unnoticed for the following 8k apart from the odd pad change. The brakes are reliable and powerful even with the original Tektro rotors so I would suggest keeping the rotors if they are straight and not very worn and just clean them up before fitting new brakes
Thanks Panter, I didn't know about checking the fork specs. I have RockShox Tora 318 SL, not sure in the manual where to check .
Until recently I didn't even know that they came in different sizes. When I changed my rear cassette from an 8 to a 9 speed I was recommended to change my chain.
Just wanted to make sure it wasn't the same with disc brakes and rotors. I'm mainly asking in case I see a good discount in January. Based on your recommendations I will save my money and just get the brakes unless the brakes rotor combo deal is near the same price.
This is the exact opposite of my experience with pads on my commuter bike. I have always found resin pads to give inconsistent braking performance, be extremely noisy when damp or wet and have a short service life, often requiring replacement due to poor friction characteristics when there is still a good third of the 'meat' left. Metallic pads have proven to give reliable performance in all weathers, rarely squeal or graunch when wet and give consistent braking right throughout the life until the metal backing plate is reachedIf you are riding on sealed roads in the wet, you're better off with resin pads which work well in the wet (albeit don't last long in wet gritty conditions). Metal pads last long in the wet but require higher operating temperatures to work properly. They are also very noisy.
