My humble Ford has 'keyless go'
So old hat
Its all done with a swipe of a credit card these days
Same here , keyless entry . Still need the key fob on you. The Merc has an app and I can open lock the doors etc remotely . See tyre pressures etc . However other than that it’s still quite gimmicky !My humble Ford has 'keyless go', but there is a key blade inside the fob.
This means that with a bit of fiddling I should always be able to get inside, although once in there's nowhere to stuff the key blade, so I think I'm still reliant on the remote fob telling the car it can start.
Everything to do with cars seems to require an expensive swipe of a credit card!So old hat
Its all done with a swipe of a credit card these days![]()
This was true, one place I worked at had 2x Cortina’s you didn’t bother picking up the correct keys for the car as one would unlock/start the others, it was pointlessAnd if you had none of those a number of keys borrowed from other Ford* drivers later would undo the lock.
* insert make of any car of the period as applicable
I once managed to get into my Fiat Panda with a bent coat hanger. My garage man told me how to. It was surprisingly easy. I don't know how to hot wire cars though.I had a Capri with keyless entry.
Nail file, screwdriver, hair clip, you name it and it would open it.
I've not needed a charger in the wild since June I think ?Dispatches on CH4 , all about EVs. We have a long way to go with charger reliability out in the wild ! That’s the message !
Not everyone has a drive or charge point to charge their vehicle at their house. That’s the point but we have done that conversation.I've not needed a charger in the wild since June I think ?
I saw Top Gear. Nobody's going to be ragging their cars round a field and up a hill on a caravan holiday.Not everyone has a drive or charge point to charge their vehicle at their house. That’s the point but we have done that conversation.
Top gear also did their thing with EVs and towing . Ok the usual light entertainment with that however it did show up the downsides of where we are with that subject.
Well aware it was Top Gear and that’s what they do but your missing the point being made underneath. You will be recharging frequently however maybe battery tech will have vastly improved by then .I saw Top Gear. Nobody's going to be ragging their cars round a field and up a hill on a caravan holiday.
And real people would plan for a recharge just like they'd do if it was a petrol car.
