smutchin
Cat 6 Racer
- The Red Enclave
How good are studded "ice" tyres? I've never used them - can the bike still slide from under you at extreme angles, or do the studs run out to the sides far enough to stop that happening?
Just to add to what has already been said, Marathon Winters are designed specifically for riding on icy roads. They have no studs in the centre of the tread, so in theory they're not much different to normal tyres when riding in a straight line on tarmac, as long as you have them at a high-ish pressure (still nowhere near normal road bike tyre pressure though). If you hit an icy patch and start to slip sideways, that's when the studs dig in and save you from a fall. It's quite unnerving the first few times it happens but once you get used to it, it feels great and fills you with confidence.
There are different tyres with different stud patterns for riding in snow.
I have read this thread with interest as I have been told that studded tyres will be ruined by riding on tarmac for even a short distance, the studs pulling out of the tyres.
It seems from the above posts that this is not true, or has anyone had this happen ?
I've lost a few studs from mine but not enough to cause concern. As mentioned already, it is possible to replace them.
