Team, does the typical modernish 10mm rear axle have an M10 thread? Cheers.
Drago Legendary Member Location The Urban Fringe 29 Mar 2017 #1 Team, does the typical modernish 10mm rear axle have an M10 thread? Cheers.
Tim Hall Guest Location Crawley 29 Mar 2017 #2 M10 x 1mm. Your average M10 bolt lying around the shed is much more likely to be M10 x 1.5mm, ie the axle is a finer pitch.
chriscross1966 Über Member Location Swindon 29 Mar 2017 #3 Campagnolo axles are still 9mmx26tpi aren't they?
OP OP Drago Legendary Member Location The Urban Fringe 29 Mar 2017 #4 Tim Hall said: M10 x 1mm. Your average M10 bolt lying around the shed is much more likely to be M10 x 1.5mm, ie the axle is a finer pitch. Click to expand... Thanks Tim, that's exactly what I needed to know.
