barrel-adjuster
Hi is the barrel-adjuster meant to also turn the black tubing it is on as well. I am tinkering with an old bike changing the gear cable to learn whats what. But to tweak it I am finding it hard to turn the adjuster as the tubing wants to turn as well. I have taken it all part and it seems to be one part ?
Well I got the cable installed and gears indexing quite chuffed and I was surprised how slack the cable had to be for things to work smoothly
lpretro1
No - the outer casing shouldn't rotate. It needs taking out, cleaning and putting back with a bit of lube to stop it doing that. If you don't the inner wire will be twisted around inside which is not so good. Some set-ups the cable may have to be slacker than is ideal to get it to work - especially on cheaper bikes...
captainhastings
West Wales
Thank you in that case then the twisty bits are pretty well seized on the tubing. It is working fine now so next time I might just replace them. I did unscrew them all the way off to look but they looked one piece
