I have managed to remove quite a few of these when others have failed. If you have a bench with a vice attached to it, then it is a relatively simple and straight forward task.
Assuming that you already have the spindle out, soak the internal threads of the bottom bracket with a little diesel for a couple of days. Place the flats into the vice jaws and tighten them. I know this is a left handed tread, but try rocking the frame both anticlockwise and then clockwise a few times to break the rust/corrosion seal, and then continue to turn the frame clockwise to unscrew the cup. it may help if you rock the frame anticlockwise and then clockwise every now and again as you add a few drops more of diesel to help clean and lubricate the treads.
