- Glasgow
No
Are we not supposed to cycle on the left anyway in the UK?
... or in equally poor taste....
Do you use performance enhancing drugs to make your lance arm strong?
I always go to the left , but I have discovered that there are cyclists that are not aware of keep left whilst passing , I have as recently as Tuesday had run in's with some of them
So you signal left which means you are going to the left. Although maybe they think you are telling them to go left. Best thing is to slow down enough so that it isn't really an issue.
Around here if there are multiple peds it is obligatory to walk spread out across the cycle path, so if there is more than one aim for straight down the middle, that way they will jump either way in surprise.
If there's only one just squeeze through wherever you want.
