Harrisman
- montrose scotland
I have been told that i cant use a campagnolo cassette with a shimano tiagra crank. But my mechanic says my 9 speed cassette with an 9 speed chain on my tiagra's crank will work ok ?????????
My shifters are shimano...you can use shimano chainset with campag cassette without any problem. the problem when mixing shimano and campag comes when you try to mix gear shifters
In simple terms you cant use a Campag cassette with Shimano shifters.My shifters are shimano...
Does that mean my campag cassette. Wont work with my shimano crank chain and shifters ?????In simple terms you cant use a Campag cassette with Shimano shifters.
The length of cable pull with each shift is different between Shimano and Campag, so the spacing between cogs is different.
You can however use any 9 speed chainset, Campag on Shimano, Shimano on Campag because the distance between the chain sideplates is the same...so the chainrings are the same thickness.
Yes he did - and all the correct advice has been given.didn't you already ask this question twice yesterday..??
I told my mechanic what you said. and he said to leave the campag free hub. and put a campag cassette on it. and it will work ok. as hes done this before. I am only wanting to get it right. i dont want to waste anymore moneyyesterday, I told you that you would need a new shimano freehub to replace the campag one currently fitted to your wheels. What has changed since then..??
BTW - forget about the Tiagra crankset - it is totally irrelevant.
I assume he will give you your money back if it doesn't work - let us know.I told my mechanic what you said. and he said to leave the campag free hub. and put a campag cassette on it. and it will work ok. as hes done this before. I am only wanting to get it right. i dont want to waste anymore money
.9sp shimano shifters will work with a 9sp campag cassette providing you use a shift-mate or similar conversion device, but that isn't what you asked yesterday. You asked if your campag freehub could be swapped for a shimano item - and I said it could.
I would just leave all this to your mechanic - he seems to know what he is doing and in the meantime you just seem to be confusing the issue.
