Bike Type Advice
lukejaii
Hey, I've read the sticky dedicated to newbie bike choices, but I'm still not sure what type I should pick.
I would be primarily using my bike to travel to the gym and back, a round journey of about 5 miles. It's pretty much flat, but a lot of the time I will be going over bumpy old roads and up and down pavement. Is a hybrid still suitable for this?
helston90
Eat, sleep, ride, repeat.
Cornwall
From your description I would say any type of bike would handle it- you may want something a bit chunkier to make the bumpy roads more comfortable but a road bike would happily handle them.
What sort of budget do you have?
When you say 'up and down pavement' I assume you mean cycle path/ road yeah? not the actual pavement with people walking.
ScotiaLass
Middle Earth
Hi :smile:
I think a hybrid would suit what you want.
There are several types, i.e you can get hybrids with front suspension, but it really depends if your route is really bad and if weight is a factor (bikes with suspension are usually a bit heavier)
Will you be cycling further than your 5 miles? If you think you may cycle more then you may want to consider something else!
L
lukejaii
My budget is 200-300, at a push 350. I would probably use it to cycle more than 5 miles 2 or 3 times a month.
I was talking about pavements, is there a problem with that? Excuse me if I'm being naive, I'm 17 so I've not got the best knowledge of road laws.
If I was to be doing any cycling at the weekends, it would be on country side roads that are riddled with potholes, incase that affects my choice.
It's against the law to cycle on the pavement as an adult (17 is an adult when it comes to cycling in my book), Shared paths are ok, but remember pedestrians have right of way so ride cautiously and slowly. A bell is good to warn others you are coming :smile:
Have a look at the Carrera Subway range from Halfords :smile:
If I was to be doing any cycling at the weekends, it would be on country side roads that are riddled with potholes, in-case that affects my choice.
Very hard to recommend a bike for someone your age, because at your age you will more than likely want to change your mind as to what you want to use it for. I would say buy a Hard tail mountain bike, This will allow you to commute to your gym, it will also allow you to go out and play on the trails. Something I have found Teens like to do.
Once you have been cycling for a while you will soon find out if you want to go for a road bike or continue with a Mountain bike.. Visit your local Bike shops, and see what they have on offer and what they recommend. I would recommend you also buy a copy of Cycle craft http://www.cyclecraft.co.uk and a copy of the highway code, This will allow you to be more aware of the recommended practise for cycling on the roads, As to riding on Pavement, it can get expensive if caught, also what a lot of cyclist do not realise is if the pavement is split by a white line in two sections one for pedestrians and one half for cycles, it is against the Law for a cyclist to cross over the white line into the Pedestrians section and in some towns they will issue a fixed penalty fine.
sreten
Brighton, UK
http://www.bikeradar.com/gear/article/best-cheap-hybrid-bikes-39802/
Hi,
FWIW a 5 mile round trip can be done on anything, especially seeing your 17.
New, I'd consider a basic utility bike. Then as you learn about bikes
and what you wan't a carefully chosen used bike along the line.
rgds, sreten.
