chriscross1966
- Swindon
Hi folks...
Well I've managed to put a Campy Ultratorque in my Brompton but I have an issue... if I tighten the axle screw up to stated torque (55nm) then the pedals are very stiff to turn, it reminds me of the sensation after I overtightened the old cup and cone bottom bracket on my Raleigh Chopper when I was 10...
I've tapped out the bottom bracket and faced it using the Lifeline kit from Wiggle, that all went well, though facing took way longer than I expected. Having looked at the BB before I started I can see why people do it, the paint was the least of the worries there, on both sides there was extrusion of the threads outwards making the surface completely uneven... anyway, that isn't the case now, the cups should be completely square and torqueing them in was a joy, I could run them in by hand until they touched down, then it took a tiny amount of movement on the torque wrench to take them to 35nm.... about an eighth of a turn, if that... So why is it binding?
Would I be advised to take the wave washer out? I've got a nasty feeling that I'm going to have to space the right hand cup out in the longer term to keep the spider from fouling the rear frame as it folds, If I wanted to add a millimetre to the drive side with some shims I have on order would that mean I have to shave a millimetre off the left hand of the bracket or are there ways to get round this?
