Binning old wheelsets.
Mugshot
Cracking a solo.
I've been sorting my shed out and have two sets of wheels one set of Aksiums and the other is a set of Zondas. The Aksiums I have actually blown the rim on the rear and the Zondas are on the wear limit, but as far as I'm aware the hubs are ok. Do you think it's worth getting them re-built or would I be just as well to bin them? What does everyone else do?
Threevok
Growing old disgracefully
South Wales
If the hubs are OK then rebuild (or if you are like me - stick them in the attic with every intention of doing so)
Mugshot
Mugshot
Cracking a solo.
I've never rebuilt a wheel although I am tempted to give it a go myself. I suppose the cost of someone who knows what they're doing rebuilding them would probably be prohibitive
Loch side.
Well, now's your chance to learn. Get a replacement rim for the wheel with the most spokes ('cause those are the easiest to do) and tackle it as a winter project - learn to do a rim transplant, tension and true. It is more satisfying than TV. Admittedly less satisfying than beer, but still, do it.
Mugshot
Mugshot
Cracking a solo.
You could be on to something there. Should the spokes be replaced at the same time?
Loch side.
No, let sleeping dogs lie. You don't even disturb them in the transplant. Here's how you do it.
1) Sedate the wheel.
2) Tape the new rim flat against the old rim, lining up the valve holes nicely.
3) Loosen a nipple, move spoke over to the adjacent rim and turn the nipple back on with a turn or two.
4) Repeat.
5) Tension and true.
Step 5 may or may not be to (time) scale with the other points, but that's a topic for another day or, from a good book or, from YouTube.
Edit: I forgot to mention that you should un-tape the old rim after the op.
Mugshot
Mugshot
Cracking a solo.
4) Repeat.
Thank you @Yellow Saddle , it sounds quite doable when you put it like that :smile:
winjim
4) Repeat.
Does this assume that you are using an identical rim, or at least one with the same ERD?
classic33
Leg End Member
4) Repeat.
Hit it with a hammer or use a local?
Loch side.
As a novice who abhors pesky steps do I need to Google ERD?
Effective Rim Diameter. It is the measurement of the rim that determines the spoke length and not the tyre size. A deep section carbon rim has a smaller ERD than a shallow box section rim. The carbon rim would use shorter spokes, but both can use the same tyre. ERD on a 700C wheel is typically in the 600mm range, giving you a spoke length from 270mm to about 303mm, depending on the hub size. Even the slightest mis-match of ERD will render the existing spokes useless since they only have about 5mm of adjustment via the nipples.
ERD is tricky to measure and the problem with searching for an alternative rim with the same ERD as yours means that you have to a) know what your present ERD is and b) find one that matches even though the ERD is generally not published and the dealer will have no clue.
That's why it is pesky.
You did ask.
