Hi
I wanted to try out Bkool for the first time this evening - but I couldn't even get started.
Just for background, I don't have a smart trainer, just a normal one with speed and cadence sensors.
The problem is, Bkool will pick up and connect to my speed, cadence and heart rate sensors, but for some reason it won't read the speed sensor properly. On the pairing page, I can see it accurately reading myheart rate and cadence values, but the speed value jumps up and down/oscillates between 0 and ~10km/h. The speed sensor is definitely not faulty, as it works perfectly with my Garmin Edge unit, just not with Bkool. As a result, when I go to start a route, it won't actually start as it will only read my cadence but not my speed.
Any ideas what the issue could be? I've even tried with two different laptops, and two different ANT+ dongles - exact same issue! Very annoying.
