Hi thank you very much for that. We thought this was the case. However the right shifter couldn’t be fitted due to it not being compatible with the deore rear drailure so we are going to have to change the rear drailure to one that is compatible. We are also thinking of changing the square taper bottom bracket that it came with to a shimano hollow tech and putting a tegra crank on would this work do you know?
Unfortunately it seems that the bike Halfords supplied has a mixture of parts that probably shouldn’t have been put together. It cost us £120 to change to a trim shifter!
Front Derailleur: Shimano Tiagra FD-4700
Replacement LH shifter: https://bike.shimano.com/products/components/pdp.P-SL-4700.html
Compatibility:
The SL-4700 2x10 speed shifter set is compatible with Shimano Tiagra FD-4700 2X10 speed front derailleur
"Shimano SL-4700 Tiagra (flat handle) 2x front shifter has 4 positions:
Shifter replaced was (best guess) Shimano Deore 2x10 (SL-M5100-L)
- High
- High trimmed
- Low trimmed
- Low"
Assume this: https://bike.shimano.com/products/components/pdp.P-SL-M5100-L.html
Looks to me that the shifter fitted was not said to be compatible with the FD-4700 fitted (as sold by Halfords).
For flat bars the only option shown is "SL-": the "STs" are all for drop bars.
Replacing as you've done seems correct, but expensive given Halfords sold you a set up Shimano doesn't offer as compatible.
