cacique
- on the briny
I have been pulling one of these behind my MTB since 1995, touring on/off road, groceries shopping, and moving tools and equipment for work.
Now back from a two week tour of Serrania de Cuenca in Spain with my partner using the latest version of the trailer with an MTB and myself using an original version with a Surly Cross Check road bike, I thought it time I should add my comments for consideration.
I think the first thing to understand about the Yak is that it was conceived to pull loads off road and it is therefore very robust and consequently somewhat overbuilt for road touring. Even before you load the trailer you already have 17 lbs of extra weight to pull and transport on a plane or train. This issue could be addressed with the use of more expensive materials and components but would put the trailer in a different and more expensive category. My feeling is the makers stuck with the steel construction and beefy design so they could continue marketing it to do what it does best, giving long service at carrying heavy loads over relatively short distances and off-road touring with remarkable reliability down to a price.
This additional weight then quickly begins to outweigh then benefits of using a trailer as against panniers for the weight conscious road tourer, especially when you consider, as another poster on trailers points out, there is definite tendency to rather overdo your packing simply because you can. The result is a slow ride. On our recent Spanish tour in hot and hilly terrain we were making 50km during a six hour riding day, not spectacular but we were able to carry all we needed for comfort and sustenance for a camping tour where water stops could be as much as 30km apart. We encountered another British couple on this trip our age making 100-120 riding an eight-ten hour day loaded with back panniers and bar bags.
Slowness aside the Yak still makes the bike feel much freer when riding than with panniers and the ability to stand up and peddle is a joy for relieving saddle sore or powering through traffic or assisting on long climbs. Weight and the consequence slowness are not the only issues though. The speed wobble mentioned by others is very real, though I have to say it is easily avoided by the the simple expedient of slowing down a little. The Yak's worst traits however are reserved for manoeuvring when off the bike and these are exacerbated with a drop bar steel road road bike: a loaded trailer has a lot of bargaining power when you need to control it in tight spaces holding your bike by the saddle and or bars and frequently it will win the fight. The point with the road bike is that being more flexible and the bars narrower it is even more like trying to land a marlin with a fly rod. The MTB's stiffer frame and especially, wider bars that give more leverage, are a big help here. I really felt for the Surly in these frequent tussles and began to worry it was getting damaged. There is a way of jack-knifing the bike and trailer for parking purposes which is easy to do but less easy to undo and it is not always practical by the side of the road as it requires a bit of space and reasonably level ground. The poster who said a loaded trailer should never be unhitched i think had not mastered the technique of doing so. With the bike and trailer in line and especially with someone holding your bike for you it is quick and safe and one of the joys of the Yak that you can unburden your bike so easily and get your gear to were you need it even if not your bike.
For light swift touring then the Yak is not I think ideal. Panniers are tried and tested and are probably a better choice. But for expeditions, off road tourers or kitchen sink merchants; good people wanting to avoid using the car for a mid week trip to Sainsburys and perhaps for the tradesman with not too many tools to carry it is really a very well thought out and effective. My original trailer cost 250 pounds is 16 years old and still going strong. My new one one was 320 USD and will probably outlive me.
Despite my misgivings and an occaisional need to swear at it I will continue using my Yak for the uses mentioned above, unless I actually get around to building a nice light aluminium or carbon version with a better bag and wheel...
