I'm beginning to wonder if Yellow Saddle has actually built & ridden his wheels - I certainly have, for over thirty years.
You seem to disagree with me and my guess is that you disagree with my last post. Your only evidence is that you've ridden bicycles for thirty years. That proves nothing. That guy there on the corner building site pouring concrete into moulds with steel reinforcing has been doing so for thirty hears but he can't calculate stresses and strains in civil engineering structure. I've been drinking beer for 30 years and know nothing about yeast.
The emotive cocktail of painting me as a non-rider non-builder also does nothing for your argument. Let's stick to the science.
By suggesting that building a wheel 4X rather than 3X will even out the tension, you misunderstand fundamental physics.
Yes, there is a difference in tension in the left spokes and right spokes of a dished (typically rear) wheel. That is because the bracing angle differs. It is like a flagpole with two guy ropes. One rope is close to the pole, one is further. the further one requires less tension than the closer one to keep the pole straight.
I quickly calculated the bracing angles on a wheel for a typical mountain bike wheel (27" size rim if you care) with a typical (Hope PRO II) rear hub. The bracing angle on the left is 6.6 degrees and on the right 4.9 degrees. That translates to a tension on the left only 73% of what it is on the right. Note that the ultimate tension doesn't matter. In order for this wheel to be centered over the hub, the left tension has to be 73% over the right tension.
Now, you say that by crossing the spokes 4X instead of 3X you can reduce that difference. The point you miss is that making the spokes longer (which is what more crosses do, you can change the tensions and therefore the angle. You can't The bracing angles remain exactly the same.
Analogy: Flagpole erected on the edge of a large step is supported by two guy ropes. One guy rope is anchored down below and the other on the upper step. The rope anchored down below is longer, but its tension remains the same as should it have been on a level field and the two ropes are on the same level.
Would you like to comment?
