Brake block retaining bolt
Willd
Rugby
After 12,000 miles and due to the fact that the brake lever was making contact with the handlebars, I thought it was time to fit some new brake blocks :whistle:
LHS no issues, couple of minutes and done; RHS the tiny aluminium bolt that holds the block in was seized solid and the 2.5 mm Allen key head on it has rounded off :rolleyes:
Short of getting a new block holder is there an easyish way to get the little bugger out?
I wouldn't bother trying to rescue it. Get new pads and holders. Not expensive
Big John
Any chance of a photo please? So you're replacing just the rubber blocks into an existing holder? This is a road bike with dual pivot calipers? Or am I way off the mark here?
Willd
Willd
Rugby
Yes, pretty much similar to this:
Both the little bolt and brake shoe are aluminium and it's corroded in.
Big John
And then? He's not trying to 'save' the brake pad: needs replacing, and 'a' little screw back in to secure the new pad.
Agreed but it's not the perfect solution. If he ever wants to adjust the block in respect of the rim how does he do that? As Trump says "Drill, baby, drill". Then it's fixed. Properly.
Ajax Bay
East Devon
"the tiny aluminium bolt that holds the block in was seized solid - 2.5 mm Allen key head"
Fossy (post #2) ftw.
